Cut out in "3" but power stayed on and still worked in "2" : NOW FIXED
Verfasst: Do 19. Dez 2024, 15:35
I think I have bad news.
I was on a ride with some hills, and using full power in "3" intermittently.
Near the end of my trip, I was in "3" and full power as I was slowing down on a hill. Just before the top it cut out.
There was a slight click/thud which I think was just the torque cutting suddenly. No indication was shown on the dash, which remained lit and active throughout.
It rolled to a stop at the top of the hill.
After it had stopped, without powering off, I cycled P and back to "1" and it had drive.
So I set off again in "1", full power OK, then "2", full power OK, then "3" and 'click', the torque cut out again.
I went home in "2" and tested this again near home, in case I had to push it. It would cut out in "3", changing to "2" whilst rolling to a stop did not help, but once stopped it was ready to drive off in 2 again within 2 seconds.
My questions;
- is this a known thing? If so, what and how to test it.
- If not, then perhaps it is a bad cell? I do not know how the battery continues to deliver power if it cuts off, or maybe it is capacitors and the battery restarts quickly?
- I have a diagnostic lead, can I deduce anything with this, and can I analyse the cell voltages in the pack?
The pack is currently at 74.7V, so perhaps ~65% charged if all the cells were balanced.
The pack has been routinely charged to full (for balancing to happen) but is not charged to full every time, perhaps 1 in 3 uses.
What should I do next?
My questions;
