Seite 2 von 2
Re: E-Max Controller 2000W
Verfasst: Fr 23. Jan 2026, 10:14
von E-Max_Fahrer
Hallo Peter,
danke für den Tip mit dem 80L.
@Chris:
I have a settings box here in Feldkirch, Vorarlberg.
If you bring your controller, we can change the settings (e.g. increase the top speed).
Verfasst: Sa 24. Jan 2026, 01:55
von Chris Magic
Hello Marco,
i would put a new battery 60 Volts and then set parameters via software to the controller that Is programmed for 48 Volts...infactly i Need firstly a software firmware for modify my e-max scooter
Verfasst: Sa 24. Jan 2026, 10:46
von Peter51
There ist no Software for the proud-eagle Controller. You need the setting Box. I think 60V nominal voltage is too high for the controller.
Verfasst: So 25. Jan 2026, 23:58
von Chris Magic
Hello Peter i'm italian and i live in south Italy....i would ask you to explain me what i can do or what Is exactly the setting box i have to find for set the scooter because i don't have each others Infos about.........thank you
Christian
Verfasst: Mo 26. Jan 2026, 11:31
von Peter51
The setting Box ist a handhield to Change the Parameter of the Controller.
Verfasst: Mo 26. Jan 2026, 11:45
von Chris Magic
Is possible to buy One around ?or Is too exoensive machinary..
Verfasst: Fr 6. Feb 2026, 16:04
von Chris Magic
I'm disperate for find a setting box compatibile with e-max 4000w 48 Volts and buy one.
if you put a picture here of setting box or, a internet link i'll praise for that thank you
