Seite 25 von 29
Re: Tromox Mino
Verfasst: Mi 21. Jun 2023, 17:57
von Nickster
I have been searching for a while now!
Where did you find the LB GUI v121.20.2300?
Re: Tromox Mino
Verfasst: Do 22. Jun 2023, 09:56
von vlad_vy
deadropine hat geschrieben: So 16. Okt 2022, 19:37 @vlad_vy
I cannot attach the software in the forum but you will find the software in this dropbox:
https://www.dropbox.com/sh/2yuly30y734x ... tracking=1
Re: Tromox Mino
Verfasst: Mi 12. Jul 2023, 09:34
von vlad_vy
Ich habe die CR2450-Batterie auf der Fernbedienung ausgetauscht. Ursache: Die Anerkennung der Fernbedienung ist instabil.
Re: Tromox Mino
Verfasst: Sa 12. Aug 2023, 13:19
von DKtromox
vlad_vy hat geschrieben: Di 4. Okt 2022, 06:39 deadropine,
Just got USB-RS485 (CH340) adapter. LB GUI 4.00 do not work for me also. Now I use LB GUI v121.20.2300. Controller software version is v121, so the last working version LB GUI will be v121.20.2300.
Is there anybody who can upload a picture of your physical connection with the control unit?
Re: Tromox Mino
Verfasst: Sa 12. Aug 2023, 20:59
von DKtromox
What is the maximum performance you can get out of the OEM Tromox Controller?
Which parameters can be changed in the OEM Tromox Controller?
Screenshots of performance enhancing settings in the original OEM Tromox Controller?
Re: Tromox Mino
Verfasst: So 13. Aug 2023, 17:56
von vlad_vy
Re: Tromox Mino
Verfasst: Do 17. Aug 2023, 20:56
von DKtromox
Every time i try to disable the speed limit, and press upload, it comes back on as enable? Am i doing anything wrong?
Re: Tromox Mino
Verfasst: Do 17. Aug 2023, 21:35
von DKtromox
Everything setting i change, keeps changing back every time i push upload, is there anything else i need to do, to be able to change settings?
Re: Tromox Mino
Verfasst: Do 17. Aug 2023, 23:05
von Schnabelwesen
Hi Danish tromox,
the Lingo controller works the other way round. Upload means uploading from the controller to the computer. Download is correct: with this you download your settings to the controller.
Best regards, Bertolt
Re: Tromox Mino
Verfasst: Fr 18. Aug 2023, 11:24
von vlad_vy
I couldn't change the speed limit by any settings in the OEM Controller. Maybe you'll have better luck.
