Re: M+ Alarm system responds moderately or not at all.
Verfasst: Mi 20. Nov 2019, 11:59
It is common that the alarm module does not function on Niu scooters when the main battery pack is disconnected.LondonBoy hat geschrieben: Mi 20. Nov 2019, 09:52 Ich denke über den Kauf des M + nach, habe aber gerade herausgefunden, dass der Alarm nicht funktioniert, wenn ich die Batterie herausnehme. Dies ist sehr enttäuschend, da es in der Nacht ist, wenn ich die Batterie im Haus auflade, wenn das Fahrzeug am anfälligsten ist und den Alarm benötigt
Funktioniert das GPS-Tracking auch ohne Akku? Wie wäre es mit dem Vibrationsalarm?
The ECU contains the GPS and Gyroscope modules, the ECU also has its own (18650) battery cell, which is charged by the main battery pack.
The Gyroscope detects whether the scooter is leaning, vibrations and movement.
The security alerts of the GPS and Groscoop modules send notifications to the Niu App/server, no matter if the main battery pack is connected or not, as long as the ECU (18650) battery cell is sufficiently charged.
The alarm module itself has its own vibration sensor, if it detects anything, the alarm will go off, provided the main battery pack is connected, because the alarm module is not connected to the backup power supply of the ECU.
I also expected it to be an interplay, but this is not the case.
The alarm module gives a signal to the ECU when it detects something, the ECU sends a message to the Niu App/server.
If one of the other modules (GPS & Gyroscope) detects something, a message is also sent to the Niu App/server, but the ECU itself cannot communicate with the alarm module, that's a pity.
Important is which ECU variant you have.
Forget the gyroscope story if it concerns an ECU v2, last OTA/firmware TRA01C19.
At least the ECU v3 or u3 is needed, last OTA/firmware TRA01E07. (Exception for the NGt&Pro, which has its own series: NXA01Bxx)
Es ist üblich, dass das Alarmmodul bei Niu-Rollern nicht funktioniert, wenn der Haupt-Akkupack abgeklemmt ist.
Das ECU enthält die GPS- und Gyroskop-Module, das ECU verfügt auch über eine eigene (18650) Batteriezelle, die durch den Haupt-Akkupack geladen wird.
Das Gyroskop erkennt, ob sich der Roller lehnt, Vibrationen und Bewegungen.
Die Sicherheitswarnungen der GPS- und Groscoop-Module senden Benachrichtigungen an die Niu App/Server, unabhängig davon, ob der Hauptakku angeschlossen ist oder nicht, solange die ECU (18650)-Batteriezelle ausreichend geladen ist.
Das Alarmmodul selbst verfügt über einen eigenen Vibrationssensor, wenn es etwas erkennt, ertönt der Alarm, vorausgesetzt, die Hauptbatterie ist angeschlossen, da das Alarmmodul nicht an die Notstromversorgung des ECU angeschlossen ist.
Ich habe auch erwartet, dass es ein Zusammenspiel ist, aber das ist nicht der Fall.
Das Alarmmodul gibt ein Signal an das ECU, wenn es etwas erkannt hat, das ECU sendet eine Nachricht an die Niu App/Server.
Wenn eines der anderen Module (GPS & Gyroscope) etwas erkennt, wird auch eine Nachricht an die Niu App/Server gesendet, aber das ECU selbst kann nicht mit dem Alarmmodul kommunizieren, das ist schade.
Wichtig ist, welche ECU-Variante Sie haben.
Vergessen Sie die Gyroskopgeschichte, wenn es sich um ein ECU v2, das letzte OTA/Firmware TRA01C19, handelt.
Mindestens das ECU v3 oder u3 wird benötigt, zuletzt OTA/Firmware TRA01E07. (Ausnahme für die NGt&Pro, die eine eigene Serie hat: NXA01Bxx).
See the ECU variations and the battery cell / Sehen Sie sich die ECU-Variationen und die Batteriezelle an.
viewtopic.php?f=63&t=8395&sid=2589d90d5 ... c&start=09
