Seite 9 von 16
Re: Lingbo Controller einstellen
Verfasst: Do 21. Jul 2022, 14:31
von Kadett 1
Hello,what Software do you use? Can you Upload it Here? My Interface is in chinese.
Verfasst: Do 21. Jul 2022, 14:42
von Kadett 1
It Looks like your second battery cable is connctet...
Verfasst: Fr 22. Jul 2022, 15:19
von gundaf
@yashwanthnu: yes it would be great to get the Software v5 in English, pls. provide
did the motor run ? or is he like dead? try to turn it a little bit by hand.
@ Kadett1: I've got the CN Controller Lingbo 72252 yesterday
now my first experience:
Self learning isn't working like it should
After bring in my settings, the engine is running, but the RPM are low ~ 780-800 rpm (depends on the battery status).
Top speed (GPS - Speedometer w/o function and Mode also on "P") = 63km/h, with the Original controller I have a top speed ~70-72 km/h.
in my opinion the engine can easily go up to >1000 rpm, but all setting I changed --> no impact.
how you did solve this challenge?
Verfasst: Fr 22. Jul 2022, 15:33
von Kadett 1
How much Volltage du you have?
Verfasst: Fr 22. Jul 2022, 15:44
von gundaf
60V
Verfasst: Fr 22. Jul 2022, 15:53
von Kadett 1
Wich Motor do you have ? I have 60v 3kw Bosch 12" Motor and it is the Same. With wrong settings -120° Shift and Reverse setting it has more RPM about 900-950 .Sound and Torque are bad but I have to deal with it until my 72v Battery arrive.
Verfasst: Fr 22. Jul 2022, 16:19
von gundaf
LUQI, CN Brand 13“ 3KW 60V
I‘m in contact with my chinese friends, but till now no solution, only to increase peak to 300A und current to 100A …. no change, and I fear to overload the motor
Let’s see what is the next proposal from them
We will not give up !
Verfasst: Fr 22. Jul 2022, 16:22
von Kadett 1
My Battery BMS only accept 65 A . With 100 Ampere i fly to the moon.
Verfasst: Fr 22. Jul 2022, 19:09
von gundaf
Bisschen gespielt
Verfasst: Fr 22. Jul 2022, 19:14
von Kadett 1
Ich behaupte mal mit 60v geht nicht viel mehr. Ist das Flux weakening aktiv
