Beschleunigung
Version vom 10. März 2021, 09:50 Uhr von 1a5d17c2be5ab622ba5c13b3f7b926339510d0aa8243fc4c87ed98b4021d5403 (Diskussion | Beiträge)
[Verbergen]Beschleunigung
Tipps zur Messung:
Erläuterungen zur Tabelle:
Vergleichstabelle
Rollermodell | Akkutyp | Dauerleistung (W) | Spitzenleistung (W) | Vmax (km/h) | Rollergewicht (kg) | Zuladung (kg) | Temperatur (°C) | Reifendruck (øbar) | Akkustand (%) | 100m (s) | 400m (s) | 0-30 km/h (s) | 0-40 km/h (s) | 0-50 km/h (s) | 0-80 km/h (s) | 0-100 km/h (s) |
Goldenkey GK183 | Blei/Gel | 5000 W | ? W | 88 km/h | 180 kg | ? kg | ? °C | 2,5 bar | 100% | - | - | - | 4,0 s | - | - | - |
Goldenkey GK183 | Blei/Gel | 5000 W | ? W | 88 km/h | 180 kg | ? kg | ? °C | ? bar | 100% | 8,0 s | - | - | - | - | - | - |
E-Sprit FURY Kelly KEB72801X | LiFePO4 | 5000 W | 8000 W | 83 km/h | 148,9 kg | 108,3 kg | 27 °C | 2.8 bar | 88% | 8,7 s | 22,8 s | 2,7 s | 3,7 s | 5,1 s | 25,6 s | - |
Jonway MJB Kelly KEB72801X | LiFePO4 | 5000 W | 8000 W | 90 km/h | 129 kg | 84 kg | 15 °C | 2.4 bar | 100% | - s | - s | 5,0 s | 6,8 s | 8,2 s | 18,0 s | -
E-Max 90S | Blei/Gel | 2750 W | 3850 W | ? km/h | 160 kg | 90 kg | ? °C | ? bar | ? % | - | - | - | 8,75 s | - | - | - |
Emco Novum-Li | LiFePO4 | 3000 W | 3000 W | 48 km/h | 117 kg | 100 kg | 26 °C | 2,8 bar | 90% | 11,3 s | - | - | 9,1 s | - | - | - |
Emco Novum-Li | LiFePO4 | 3000 W | 3000 W | 48 km/h | 117 kg | 112 kg | 16 °C | 2,8 bar | 80% | 11,7 s | - | - | 9,9 s | - | - | - |
Emco Novum-Li | LiFePO4 | 3000 W | 3000 W | 48 km/h | 117 kg | 112 kg | 11 °C | 2,6 bar | 70% | 11,9 s | - | - | - | - | - | - |
Peugeot e-Vivacity | LiFePO4 | 3000 W | ? W | ? km/h | 114 kg | ? kg | ? °C | ? bar | ? % | 12,3 s | - | - | 8,8 s | - | - | - |
E-Sprit FURY MJ 2010 | LiFePO4 | 5000 W | 8000 W | 85 km/h | 148,9 kg | 104,2 kg | 20 °C | 2,4 bar | 92% | 12,8 s | 26,7 s | 6,9 s | 8,7 s | 10,7 s | 31 s | - |
E-Max 110S | Blei/Gel | 2750 W | 3850 W | ? km/h | 195 kg | ? kg | ? °C | ? bar | ? % | - | - | - | 10,0 s | - | - | - |
NITO NES 10 (2019) | Li-Io | 2650 W | 4000 W | 85 km/h | 93 kg | 100 kg | 26 °C | ? bar | 98 % | 7,1 s | - | 1,8 s | 3,0 s | 4,0 s | 7,6 s | - |
Bimie Grazie WR2 (2019) | Li-Io | 5500 W | 7000 W | 90 km/h | 104 kg | 80 kg | 10 °C | 2,5 bar | 80 % | - | - | - | - | 4,5 s | - | - |
[[Trinity Uranus R Performance (2020)][Trinity Uranus R Performance (2020) gedrosselt auf 45]] | Li-Po | 3000 W | 5000 W | 45 km/h | 111 kg | 89 kg | 2,4 °C | ? bar | 95 % | - | - | 4,5 s | 6,0 s | - | - | - |
