E-ODIN - Diskussionsthread
olliwetty
Roller: RGNT No.1 Classic SE
PLZ: 38162
Tätigkeit: Berufe an den Nagel gehängt!
Ehemals Universalfräser und Lasernarber
Re: E-ODIN - Diskussionsthread
Beitrag von olliwetty »
bob2.0 hat geschrieben: Fr 18. Okt 2024, 12:26 I have a question about charging.
I topped the battery up and went out yesterday.
I have a long ride due and set the charger on a timer for cheaper electricity at night. But it did not run and charge.
So I have discovered that at 77.6V battery voltage (9 bars showing) the charger will not put charge in. I was worried that it was a bigger issue, so went for a ride, and brought it down to 75.6V and it charges OK again, now.
I suspect this is an issue of the charger, not the battery?
Is it meant to do this, do you know, and is this the bike or the charger not allowing the charge?
War es vielleicht zu kalt in der Nacht und das Ladegerät oder der Akku lässt kein Laden zu?
Eventuell ist auch der Akku nicht gut balanciert.
Das kommt vor, wenn nie oder sehr selten der Akku vollständig geladen wird. Ich würde den Akku jetzt mal leer fahren und danach wieder komplett aufladen. Das Ganze dann 2 bis 3-mal wiederholen.
Olli
Super Soco TC Max, im März 2026 verkauft mit 23707 km
bob2.0
Roller: e-Odin 2.0
PLZ: 116
Land: anderes Land
Beitrag von bob2.0 »
I tried turning it on again manually and still did not want to know. Light went green, clicked and then turned green again.
I've charged up overnight starting from 75.6V, and it's been fine, filled it up to 100%. Now reading 83.4V. Ready to go on my trip today.
I'll be looking at this again one day soon, I expect. I have bought this other charger now and will put a plug on it and see what that one does. Seems sensible to have a back-up one way or another, chargers can go wrong.
Miguello80
Roller: E-Odin 2.0 6kW AMR
Land: anderes Land
Beitrag von Miguello80 »
jeff-jordan hat geschrieben: Sa 19. Okt 2024, 00:38 But I checked the whole disc with a magnet and it sticks all over the disc (with the same force), furthermore there is no gap between the black and the shiny part of it.
In my eyes the BRDF031 is one piece of steel, with a polished shiny outer ring and a black coated inner section! I can't see another functionality of the rivets, except for decoration.
Hmm, it seems you are right, my bad. I did not examined them, just put them on to get rid of warped discs. Sorry, next time I will be more thorough.
Only reason for bobbins (besides the misleading guys like me) could be to let them absorb the heat from outer part of disc faster then inner part of disc = help to cool the disc.
No matter what, as one piece it is not floating disc for sure.
But.. I have to repeat it - if they will last some time without warping, then better than original.
jeff-jordan
Roller: Classico LI & Z-Odin
PLZ: 6...
Beitrag von jeff-jordan »
Miguello80 hat geschrieben: So 20. Okt 2024, 01:35 ....
I totally agree.
And as I already mentioned, it's absolutely ok for me that they are no real floating discs.
The E-Odin isn't that kind of bike that would require the latest braking technology to push it to its limits.
More important is that you've found something that fits and most likely is better than the poor original equipment.
Classico Li 05/2020 11 000+ km & Z-Odin 12/2021 38 500+ km :idea:
bob2.0
Roller: e-Odin 2.0
PLZ: 116
Land: anderes Land
I posted recently my work on the front suspension modification.
The thread seems to have vanished.
Is there some reason for this, or system error?
Zuletzt geändert von bob2.0 am So 27. Okt 2024, 13:35, insgesamt 1-mal geändert.
bob2.0
Roller: e-Odin 2.0
PLZ: 116
Land: anderes Land
jeff-jordan
PLZ: 6...
I've seen and read your post (so you've got an eye-witness :roll: )...
But it seems that somebody (with the required rights) deleted it.
Zimmermännche
Roller: E Odin 10kw Typ2
PLZ: 555
Beitrag von Zimmermännche »
jeff-jordan hat geschrieben: So 27. Okt 2024, 18:42 I've seen and read your post (so you've got an eye-witness :roll: )...
Ich hatte es auch gelesen. Aber war das nicht sogar im Thread Stoßdämpfer? Der scheint doch auch nicht mehr da zu sein?
E-Odin 3.0S 12/2022
jeff-jordan
PLZ: 6...
Zimmermännche hat geschrieben: So 27. Okt 2024, 18:47 ...
Genau.
PLZ: 41564
Beitrag von Evolution »
Bitte füllt den Thread Stoßdämpfer wieder auf, scheint versehentlich gelöscht worden zu sein.
Zurück zu „Dayi Motors“
