Hallo Peter,
danke für den Tip mit dem 80L.
@Chris:
I have a settings box here in Feldkirch, Vorarlberg.
If you bring your controller, we can change the settings (e.g. increase the top speed).
E-Max Controller 2000W
E-Max_Fahrer
- Roller: E-Max 90S
- PLZ: 6800
- Tätigkeit: E-Ingenieur
Chris Magic
- Roller: E max 90s
- PLZ: 80100
Re: E-Max Controller 2000W
Hello Marco,
i would put a new battery 60 Volts and then set parameters via software to the controller that Is programmed for 48 Volts...infactly i Need firstly a software firmware for modify my e-max scooter
There ist no Software for the proud-eagle Controller. You need the setting Box. I think 60V nominal voltage is too high for the controller.
Chris Magic
- Roller: E max 90s
- PLZ: 80100
Hello Peter i'm italian and i live in south Italy....i would ask you to explain me what i can do or what Is exactly the setting box i have to find for set the scooter because i don't have each others Infos about.........thank you
Christian
Christian
The setting Box ist a handhield to Change the Parameter of the Controller.
Chris Magic
- Roller: E max 90s
- PLZ: 80100
Is possible to buy One around ?or Is too exoensive machinary..
Chris Magic
- Roller: E max 90s
- PLZ: 80100
I'm disperate for find a setting box compatibile with e-max 4000w 48 Volts and buy one.
if you put a picture here of setting box or, a internet link i'll praise for that thank you
