Seite 23 von 29
Re: Tromox Mino
Verfasst: Mo 9. Jan 2023, 05:18
von vlad_vy
I wrote down a reminder to cut the wire to pin 30 of the controller connector, but I still forgot about it.
Today I cut this wire, as expected nothing has changed, everything is working. In a normal situation, this wire does not affect anything, but in case of a short circuit in electronics or wiring, its presence is dangerous by wiring fire and damage to the controller, since it shorts the fuse 10A 60V and the short circuit current will go through the controller, from the terminal +60V of the controller to pin 30 of the controller connector.
Re: Tromox Mino
Verfasst: Mo 9. Jan 2023, 05:38
von vlad_vy
Electrical diagram of the Tromox Mino main cable, with CT-22 speedometer and controller LBMC072122SHK3AP-M29 (LBC100.029D).
Tromox_Mino_main_cable_CT-22.pdf
(207.74 KiB) 245-mal heruntergeladen
The Tromox Mino CT-22 speedometer connector pinout (connector viewed from pin side, male connector):
viewtopic.php?p=289475#p289475
Used connectors - "Furukawa White RFW 2.3mm" waterproof connector, 9 pin, male and female.
viewtopic.php?p=289088#p289088
Original Tromox Mino main cable:
viewtopic.php?p=291409#p291409
Main cable connectors and Left & Right Handle switches
viewtopic.php?p=291946#p291946
Re: Tromox Mino
Verfasst: Mi 11. Jan 2023, 10:05
von brabax
So, it‘s time to take on that RS485 protocol, don‘t you think? 8-)
Re: Tromox Mino
Verfasst: Mi 11. Jan 2023, 12:18
von vlad_vy
The RS485 is phisical level protocol. Thats about higher level protocols:
* LanDrive
* ProfiBus DP
* ModBus
* DMX512
* HDLC
* IEC 60870-5
Re: Tromox Mino
Verfasst: Mi 11. Jan 2023, 12:51
von brabax
Sorry, I‘ve meant: decoding the transport protocol and the messages on the RS485 port. I could not get around to it because my 18-month-old is keeping me busy…
Re: Tromox Mino
Verfasst: Mi 11. Jan 2023, 17:00
von vlad_vy
I'm afraid I can't help with that, right now I have two RS485 devices only, a battery and an anti-theft alarm. The dashboard and VCU have already been removed. The controller has been replaced with another one.
Re: Tromox Mino
Verfasst: Di 24. Jan 2023, 09:29
von Nickster
vlad_vy hat geschrieben: Mo 10. Okt 2022, 12:15 Some mods:
Front mudguard 1
Front mudguard 2
Rear mudguard
Additional chain guard
Hi vlad_vy
Did you buy the fenders, or is it something you made your self?
Re: Tromox Mino
Verfasst: Di 24. Jan 2023, 11:47
von vlad_vy
I use fenders for 47cc и 49cc Minimoto Mini ATV /QUAD/Dirt Bike. And cut these fenders for my needs. Next, clue with 3M adhesive tape (3M Automotive Acrylic Plus Tape). Additional chain guard is cut out of a plastic stationery folder.
https://aliexpress.com/item/32841613462.html
Re: Tromox Mino
Verfasst: Di 2. Mai 2023, 07:38
von vlad_vy
The factory Tromox Mino is designed for a speed of 46 km/h. Motor Kv=35.5. With the help of the stock controller, it is accelerated by 10% (High Speed Percent = 110, Flux Max. Peak Current = 10A), up to 50 km/h. Without acceleration (High Speed Percent = 100): Max speed without load = 55 km/h, speed slip = 16%, 55 * 0.84 = 46.2 km/h. The maximum speed you can get with another controller (High Speed Percent = 130, Flux Max. Peak Current = 30A) ≈ 58 km/h. Max speed without load = 69 km/h, speed slip = 16%, 69 * 0.84 = 57.96 km/h.
Re: Tromox Mino
Verfasst: Mi 3. Mai 2023, 19:03
von vlad_vy
The last setup is the best of everything I've tried. Controller LBMC072122SHK3AP-M29 (LBC100.029D).
Changed from the factory settings of the Tromox Mino controller:
Motor Design RPM = 2120 (2520*0.84=2117)
Motor Max. RPM = 2520 (55 km/h)
Speed-Loop Mode Setting = Soft
High-Speed Percent = 130 (55*1.3=71.5 km/h) (55*1.3*0.84=60 km/h)
Middle-Speed Percent = 56 (33.8/(55*1.3*0.84)=56.3%) (30 km/h / 63V * 71V = 33.8 km/h)
Low-Speed Percent = 50 (not used)
Flux Max.Peak Current =30
