E Odin Scheinwerfer
Miguello80
Roller: E-Odin 2.0 6kW AMR
Land: anderes Land
Re: E Odin Scheinwerfer
Beitrag von Miguello80 »
jeff-jordan hat geschrieben: Sa 12. Okt 2024, 08:53 Did you check a few minutes with high-beam?
Here I tested a 2,5" projector lamp and the solenoid that switches from low beam to high beam draw a little bit more than 0.8A at 12V. Which means two projection units will draw approximately 20W of power (that will be converted with 99% into heat)... even without the light emitting element (LED or Xenon light bulb).
On high beams maybe 2-3 minutes at once per ride while riding through woods etc., on the other side many long rides with low beams.
I would be more affraid of what my dascams with external display and USB charger draw from stepper :)
7 months and 3500 km after installation and so far no problem. In case that stepper would fail it is cheap part to replace. By the way my stepper looks like differently than yours, I hope that at least this part was improved :)
Miguello80
Land: anderes Land
Miguello80 hat geschrieben: Do 10. Okt 2024, 00:09 I promise, I will finish the video about new headlights this weekend so you will see how easy it is and how much difference :)
Well, I worked on it for another 8 hours during weekend and still have to edit one 1 hour long video so next week is the deadline. And that is without wiring instructions but for that a diagram is enough. So be patient with me please...
Zimmermännche
Roller: E Odin 10kw Typ2
PLZ: 555
Beitrag von Zimmermännche »
Autogamma hat sich bisher leider nicht auf meine Anfrage per E-Mail (auf Englisch) gemeldet ob sie auch nach Deutschland liefern und was es dann kosten würde.
E-Odin 3.0S 12/2022
Miguello80
Land: anderes Land
Zimmermännche hat geschrieben: Mi 16. Okt 2024, 17:46 Autogamma hat sich bisher leider nicht auf meine Anfrage per E-Mail (auf Englisch) gemeldet ob sie auch nach Deutschland liefern und was es dann kosten würde.
I wrote them on their Facebook page and they did not answer me.
Tomorrow I am going to finish the video about those projectors so you can decide and if you want them, I will order it and re-send it to you like I did it with Jeff when his seller did not have delivery to Germany as an option.
rt1970
Roller: E-ODIN 2.0 S
PLZ: 14
Beitrag von rt1970 »
Hat jemand diese autogamma Scheinwerfer bestellt?
Wie sind die Erfahrungen? Liefern die nach Deutschland?
Beim Ali sehen die Sinolyn 2,0 Inch Bi LED Angel Eyes als "Farbe": 1 Pair Of Lenses identisch aus...
Zimmermännche
PLZ: 555
rt1970 hat geschrieben: Di 18. Feb 2025, 15:41 Hat jemand diese autogamma Scheinwerfer bestellt?
Miguello hat die Scheinwerfer ja bei sich eingebaut bei autogamma hat er ja "Heimspiel". Eigentlich wollte er auch noch ein Video davon machen.
Autogamma hat sich nicht auf meine Anfrage per Mail gemeldet ob sie auch nach Deutschland liefern und was es kosten würde.
Da eine meiner LEDs im Scheinwerfer defekt war hab ich mir nochmal einen neuen original Scheinwerfer eingebaut um " in Ruhe" die HU durchführen zu können.
E-Odin 3.0S 12/2022
rt1970
PLZ: 14
Schau mal hier. Neues Video (ich glaub das ist er):
https://www.youtube.com/watch?v=sY4F9GwcA5c
Miguello80
Land: anderes Land
rt1970 hat geschrieben: Di 18. Feb 2025, 19:25 Schau mal hier. Neues Video (ich glaub das ist er):
Yes, it is me :)
I was asked to share the stl files so here it is (including the description used under the video on Youtube): https://drive.google.com/file/d/10AeSrO ... sp=sharing
(includes two photos of cockpit tilt adjustment that shared one great guy from elektroroller-forum.de and also wiring + screws)
* I believe those two photos are Jeff´s, hope he does not mind I used it.
rt1970
PLZ: 14
It is so cool, but the shop has no PayPal and i dont know if he send to germany...
Miguello80
Land: anderes Land
rt1970 hat geschrieben: Sa 22. Feb 2025, 20:30 It is so cool, but the shop has no PayPal and i dont know if he send to germany...
It seems that they do not send to Germany, who knows why, but it has a solution.
When I needed to buy something from german e-shop that did not send to my country (CZ), I googled a service of free post adress, receiving the packages and resending them to my adress for a small fee. Used it several times and worked perfectly. So maybe you can find similar company/service that will borrow you their mail adress in Poland and then resend you the package.
Or I can order it and send it to your adress, we did it with Jeff when Aliexpress or Alibaba seller did not send to Germany and PPL to Germany costed only 13 euros or so. Do not hesitate to ask, I would not offer it if I would not wanted to :)
Zurück zu „Dayi Motors“
