A battery voltage readout [OCD/autistic problem]
Verfasst: So 12. Jul 2026, 10:52
This is about me setting up a cell voltage readout, and getting it wrong, but maybe in a good way.
In the 'discussion' thread I posted the lead I made up that links a XT90 plug to the battery, via an ideal diode. This seems to run fine at 20A. This is for charging with my new charger and also the possibility of range extending batteries.
In addition to that lead and diode, I added a voltage divider across the diode output, so I can take off an average cell voltage.
I intended to add 'too much' ground resistance, so that I could then simply trim it with a bit more.
I made an error, got it the wrong way in my head, and put too little in. I did a 21:1 divide with two ~100kOhm in series (redundant protection against a component failure) and tapping that at a 10kOhm to ground. I intended to trim with a parallel resistor, but confused myself, needed to be 15kOhm to do that.
This means there is a ~21.1:1 ratio and always half a mA draining from the battery. (
it might go flat!!
Anyway, this mistake I made means that it will now read 4.0 for full cell, and 3.0 for flat.
Autistically, I dislike having the wrong cell voltage. HOWEVER! It means if the gauge reads '4' in the first digit, it is overcharged, and if '2' then it is dead.
Or thereabouts. So, easy to read. But even easier to read is the decimals, which now run from '.000' to '.999' from flat to full.
So, I will try it like that for a bit, see if it works for me. 'The Bob scale'. Not volts. 'Bobs'! But I have to get over the OCD issue that it is not 'right'.
1 bob = 1.05 volts. Cell is full at 4 bobs.
Your thoughts welcome on this set of events and errors.
