Niu NGT dont change to sport mode
mil_house@hotmail.com
Roller: Niu NGT
PLZ: 08024
Beitrag von mil_house@hotmail.com »
Hello
Before i post i try to find if some one have the same problem , but i didnt find it
Right now i cant switch to sport mode, battery is in 93%(A:86%,b:100%), i run smart test from the app but everything is fine, only problem is i cannot switch to sport mode
Any idea?or have to reset the bike o something like that?
Thanks in advance
Nicolas
tiger46
PLZ: 1100
Re: Niu NGT dont change to sport mode
Beitrag von tiger46 »
I think sportmode ist just avaible when the differenz of booth batteries is max. about 5/6% ;-) - so drive and after some miles it should work.
NGTrash
Roller: Niu NGT
PLZ: 4
Land: CH
Beitrag von NGTrash »
tiger46 hat geschrieben: Sa 20. Jul 2019, 18:41 I think sportmode ist just avaible when the differenz of booth batteries is max. about 5/6% ;-) - so drive and after some miles it should work.
I‘m able to use sport mode with a battery charge difference like mil_house, so I‘m not sure this is true. But I‘m quite curious - or borderline annoyed - that after a full charge including battery balancing, the NGT will charge one battery from the other. Thus creating such unbalanced charges - quite a bug in ECU sotware B11 I suppose.
Cooper
Roller: Indiegogo M+ no fast charging; Alarm very poor performance
PLZ: 1112
Land: anderes Land
Beitrag von Cooper »
mil_house@hotmail.com hat geschrieben: Sa 20. Jul 2019, 15:41 Hello
Thanks in advance
Nicolas
NGTrash hat geschrieben: Mo 22. Jul 2019, 14:04
Gentlemen, what's your OTA version?
With the factory installed B03 version there were several complaints, with the later OTA versions (B08 & B11) you don't hear about it anymore.
Meine Herren, was ist Ihre OTA-Version?
Mit der werkseitig installierten B03-Version gab es mehrere Beschwerden, mit den späteren OTA-Versionen (B08 & B11) hört man nichts mehr davon.
NGTrash
Roller: Niu NGT
PLZ: 4
Land: CH
B11 as stated above ;)
NGTrash
Roller: Niu NGT
PLZ: 4
Land: CH
Thanks in advance
Nicolas
Try to disconnect and reconnect the batteries. The manual states that if only one battery is powering the scooter, only eco and dynamic are available. So I guess for whatever reason, one battery got disconnected (or the ECU did not properly register it connecting).
Mitglieder in diesem Forum: tensecondtom und 15 Gäste
