Tromox Mino
vlad_vy
- Roller: Tromox Mino
- PLZ: 1
Re: Tromox Mino
Right handle switches pinout (connector viewed from pin side, male connector):
__~~~__
1| = = = |3
4| = = = |6
7| = = = |9
1) GND; 2) +12V; 3) Angel eyes;
4) Sport switch; 5) GND; 6) to Left Handle Switches (pin 3);
7) Alarm button; 8) GND; 9) READY button
Pins 2, 3 and 6 interconnected in handle.
Brake switch:
red -> 0 -> green-yellow = controller High Brake, pin 11
black -> 0 -> black = +12V
Turn Right (front):
green -> 0 -> green = GND (12V)
blue -> 0 -> light-blue = Turn Right
Throttle handle pinout:
_~~_
1| = = |2
| = |3
1) +5V; 2) Throttle signal
3) GND
__~~~__
1| = = = |3
4| = = = |6
7| = = = |9
Brake switch:
Turn Right (front):
_~~_
1| = = |2
| = |3
3) GND
Zuletzt geändert von vlad_vy am Fr 9. Dez 2022, 10:46, insgesamt 12-mal geändert.
vlad_vy
- PLZ: 1
Re: Tromox Mino
Side stand pinout:
_~~_
1| = = |2
1) Controller Function port, pin 15; 2) GND
Blinker pinout:
__~~__
1| = = = |3
1) Turn common; 2) +12V; 3) GND (12V)
_~~_
1| = = |2
Blinker pinout:
__~~__
1| = = = |3
Zuletzt geändert von vlad_vy am Di 29. Nov 2022, 10:30, insgesamt 4-mal geändert.
vlad_vy
- PLZ: 1
Re: Tromox Mino
VCU pinout:
______~~~______
1| = x x x x x x x = |9
10| = x x x x x x x = |18
1) GND (60V); 9) RS485A
10) +60V; 18) RS485B
______~~~______
Zuletzt geändert von vlad_vy am Di 29. Nov 2022, 10:30, insgesamt 2-mal geändert.
vlad_vy
- PLZ: 1
Re: Tromox Mino
Motor Hall sensor pinout:
__~~~__
1| = x = |3
4| = = = |6
1) +5V; 2) NC; 3) GND;
4) Hall A; 5) Hall B; 6) Hall C
__~~~__
1| = x = |3
4| = = = |6
Zuletzt geändert von vlad_vy am Di 29. Nov 2022, 10:31, insgesamt 2-mal geändert.
vlad_vy
- PLZ: 1
Re: Tromox Mino
DC-DC pinout:
__~~__
1| = = =|3
1) GND; 2) +12V (to fuse 10A); 3) +60V (Anti-Theft Ignition pin 8, controller pins 10 and 20)
__~~__
1| = = =|3
Zuletzt geändert von vlad_vy am Di 29. Nov 2022, 10:31, insgesamt 3-mal geändert.
vlad_vy
- PLZ: 1
Re: Tromox Mino
I think that I can place most CT-22 speedometer wires into Mino dashboard connector. I don't planning to use RS485 bus, therefore I can replace RS485 with Hall signal and +60V.vlad_vy hat geschrieben: Mi 23. Nov 2022, 06:40 The Tromox Mino dashboard pinout (connector viewed from pin side, male connector):
__~~~__
1| = = = |3
4| = x = |6
7| = = = |9
1) +12V; 2) Sport switch; 3) GND (12V);
4) Turn Left; 5) NC; 6) RS485B;
7) Turn Right; 8) High Beam; 9) RS485A
__~~~__
1| = = = |3
4| = = = |6
7| = = = |9
4) Turn Left; 5) Hall signal; 6) GND(60V);
7) Turn Right; 8) High Beam; 9) +60V (Ignition, controller pins 10 and 20)
Not connected CT-22 wires: Eco, Park, Memory line for RTC clock. Anyway, they can't be used:
Eco - no switch,
Park - no switch, and side stand connect to GND, not to +12V,
Memory line for RTC clock - replaced with internal backup battery.
Zuletzt geändert von vlad_vy am Mo 19. Dez 2022, 14:55, insgesamt 3-mal geändert.
vlad_vy
- PLZ: 1
Re: Tromox Mino
Front light pinout:
_~~~_
1| = = |2
3| = = |4
1) Low Beam; 2) High Beam
3) Angel eyes; 4) GND (12V)
_~~~_
1| = = |2
3| = = |4
Zuletzt geändert von vlad_vy am Di 29. Nov 2022, 10:31, insgesamt 1-mal geändert.
vlad_vy
- PLZ: 1
Re: Tromox Mino
Left handle switches pinout (connector viewed from pin side, female connector):
__~~~__
1| = = = |3
4| = = X |6
7| = = = |9
1) Horn; 2) Low Beam; 3) from Right Handle Switches (pin 6);
4) +12V; 5) High Beam; 6) NC;
7) Turn Right; 8) Turn Left; 9) Turn Common
Low/High Beam switch
__ (2)
(3) __/__ (5)
Cruise Button pinout:
_~~_
1| x = |2
| = |3
1) NC; 2) GND
3) Controller function port, pin 17
Brake switch:
Turn Left (front):
orange -> 0 -> orange = Turn Left
__~~~__
1| = = = |3
4| = = X |6
7| = = = |9
__ (2)
(3) __/__ (5)
_~~_
1| x = |2
| = |3
1) NC; 2) GND
Brake switch:
Turn Left (front):
vlad_vy
- PLZ: 1
Re: Tromox Mino
The crimping of the plugs is not very reliable. The second wire popped out of the plug, the right turn signal from the switch of the left handle, from the connector of the main cable. Last time it was the left rear turn signal, the plug in the rear mudguard.
vlad_vy
- PLZ: 1
Re: Tromox Mino
Controller Lingbo LBMC 060122 HK3A EU M6 pinout:
_______
1| = = x |21
2| x = = |22
3> = = = |23
4| = = x |24
5| x = x |25
6| = = = |26
7| = = = |27
8> x = = |28
9| = = x |29
10| = = = |30
1) Hall A
2) NC (Low Speed)
3) Sport/Eco switch (High Speed)
4) Hall +5V
5) NC (Foot Support Power 5V)
6) Hall GND
7) Anti-Theft Negative
8) NC (Reverse)
9) Motor Temp (grounded at Motor temp connector, function not supported)
10) Ignition (connected with pin 20, +60V)
11) High Brake
12) Hall B
13) RS485A
14) Anti-Theft Signal
15) "Side stand" (Function port)
16) GND
17) "Cruise" button (Function port)
18) "READY" button (Cruise Input)
19) Anti-Theft Motor Rolling Alarm
20) Anti-Theft Ignition (connected with pin 10, +60V)
21) NC (Low Brake)
22) Hall C
23) RS485B
24) NC (Function port)
25) NC (Function port)
26) Throttle GND
27) Throttle signal
28) Throttle +5V
29) NC (GUI 3.3V)
30) Anti-Theft Positive (+60V)
_______
1| = = x |21
2| x = = |22
3> = = = |23
4| = = x |24
5| x = x |25
6| = = = |26
7| = = = |27
8> x = = |28
9| = = x |29
10| = = = |30
1) Hall A
2) NC (Low Speed)
4) Hall +5V
6) Hall GND
8) NC (Reverse)
11) High Brake
12) Hall B
13) RS485A
16) GND
21) NC (Low Brake)
22) Hall C
23) RS485B
26) Throttle GND
27) Throttle signal
28) Throttle +5V
29) NC (GUI 3.3V)
Zuletzt geändert von vlad_vy am Di 29. Nov 2022, 10:33, insgesamt 2-mal geändert.
Mitglieder in diesem Forum: 0 Mitglieder und 66 Gäste
