Rolekto BT250
Svjatoha
- Roller: Rolektro bt 250
- PLZ: 89174
Re: Rolekto BT250
Vielen Dank. Und was ist, wenn Sie es vom Auto aus ablegen? Und addiere 24
- Pfriemler
- PLZ: 14513
- Tätigkeit: Tonkünstler
Re: Rolekto BT250
Du sprichst in Rätseln. Der Übersetzer scheint nicht richtig zu funktionieren. Again, English is welcome.
Svjatoha
- PLZ: 89174
Re: Rolekto BT250
Put the battery from the car and add 2 more small ones of 12 to make 36 V. And is it possible to sequentially add another battery to increase the power to 48v
- Pfriemler
- PLZ: 14513
Re: Rolekto BT250
Ah, got it now. But: It makes no sense to couple different batterys together to gain 48 volts - why ever? As far as I know, the BT250 uses three Pb cells in series for nominal 36 volts and you have to change a lot of parts to use 48 volts. The smallest battery in the chain determines the usable capacity and range and is in danger to be damaged by the others. In my opinion, you have to install almost three almost identical batterys. The only variation you have is the capacity. Maybe you can switch to Lithium - with a lot of further probs to solve.Svjatoha hat geschrieben: Mo 29. Jan 2024, 21:52 Put the battery from the car and add 2 more small ones of 12 to make 36 V. And is it possible to sequentially add another battery to increase the power to 48v
- Schnabelwesen
- Roller: Vectrix VX-1
- PLZ: 2411
Re: Rolekto BT250
Car batteries are generally not suitable. They are made for short starts, not for continuous charging and discharging.
Adam27081972
- Roller: BT-250
- PLZ: 71546
Re: Rolekto BT250
Hallo alle zusammen,
Meine BT-250 Rolektro will nichtmehr. Ich habe alle meine Stecker ausgesteckt und die Beschriftung ist leider abgegangen. Leider finde ich nirgends wo was hingehört. Hat jemand bitte ein Bilder vom Controller und den Stecker? Was wohin kommt?
MfG
Adam
MfG
Adam
- Harry
- PLZ: 49479
Adam27081972
- Roller: BT-250
- PLZ: 71546
Re: Rolekto BT250
Hallo Harry,
vielen Dank.
Hast du auch die gegenanschlüsse?
MfG
Adam
vielen Dank.
MfG
Adam
- Harry
- PLZ: 49479
Re: Rolekto BT250
Im Schaltplan sind die Farben der Kabel angegeben, damit müsstest du die Zuordnung herausfinden.
Gruß Harry
Adam27081972
- Roller: BT-250
- PLZ: 71546
Re: Rolekto BT250
Hey,
ich bekomme leider mit Schaltplan und mit dem Controller es nicht hin. Könnten sie mir bitte die Stecker Farben die an den Controller gesteckt werden zuordnen bitte?
MfG
Adam
MfG
Adam
