Dismantling and repairing the motor :o
jeff-jordan
Roller: Classico LI & Z-Odin
PLZ: 6...
Re: Dismantling and repairing the motor :o
Beitrag von jeff-jordan »
Hello bob, I just need to repeat myself: I'm pretty sure that I know why and when the "kissing" between the magnets and the stator happened.
It was in august 2023, when I drove the motor too hot... and the "zing-zing" sound once appeared. :roll:
:idea: The stator inside the motor can easily reach about 120°C or even more (at high current over a long period), so the diameter of the stator (nickel steel alloy assumed) extends about 0.5mm (compared to 20°C). That's enough to touch prone magnets....
If I had tried to remove the magnets you've spotted, I would have had to use brute force (because they are firmly glued and not loose), and the magnets would not have survived. :evil:
And by the way: no need to worry, I already have a spare motor inside my garage.... just in case. 8-)
Classico Li 05/2020 11 000+ km & Z-Odin 12/2021 38 500+ km :idea:
bob2.0
Roller: e-Odin 2.0
PLZ: 116
Land: anderes Land
Beitrag von bob2.0 »
Spare motor, nice!
Yes, fair, a stator expanding that much from too hot makes sense rather than rust out.
Hope the refit goes well. Don't use too much sealant! I made a mess of it first time :)
jeff-jordan
PLZ: 6...
bob2.0 hat geschrieben: Do 22. Jan 2026, 12:09 Spare motor, nice!
Yeah, in 2023 I was lucky enough to get an offer for a new motor for less than €600 (incl. shipping), that's why I jumped at the chance.
bob2.0
Roller: e-Odin 2.0
PLZ: 116
Land: anderes Land
jeff-jordan hat geschrieben: Do 22. Jan 2026, 14:18
My strong advice is to keep it dry and warm in storage!
I was thinking to actually put active desiccants within the motor enclosure, cable tied to the stator. As it is meant to be a generally sealed unit, then I figured maybe that would help. In the end, I glued the new magnets on, making sure to fill the gap behind the magnets (as you know), then spray a clear lacquer on them (not sure if it will do much) then also I smeared Dexron over the magnets, just a thin film, figuring it'd go somewhere useful.
Smearing a film of Dexron is something I tried on the 2nd repair iteration, and on the 3rd/final iteration it seemed to be OK and not cause any harm at all. It just disappeared somewhere and left a greasy surface, which is perfect. I considered gear oil and other lubricants too, but Dexron has the highest material and electrical compatibility of any commonly available high shear (gear-bearing) lubricant, so I figured it was probably the least-risk option for that purpose.
Zurück zu „Dayi Motors“
