NQiX 500 im Alltag – Wie sind eure Erfahrungen nach den ersten 1.000 km?
Rund um NQiX 150 / 300 / 500
Frog
Roller: NIU NqiX 500 / Lambretta 125 DL
PLZ: 3000
Land: CH
Re: NQiX 500 im Alltag – Wie sind eure Erfahrungen nach den ersten 1.000 km?
Beitrag von Frog »
Michele hat geschrieben: Do 10. Sep 2026, 18:29 I would add another thing that can be fixed: the regenerative breaking.
1) Some times, the regenerative breaking does not work when going down the slopes. If you push the throttle One Moment, It starts working again.
2) below 30km/h it does not work at all.
3) why if you push the brakes the regenerative breaking does not work? I find this silly, especially on steep and long descents.
1: If you let the scooter roll down the road, holding throttle steady (not adjusting down), the scooter gets faster and consumption drops to 0 watts -> It won't recuperate this way, instead it gains speed. If you turn the throttle down or, if cruise control is set, turn throttle first up then down, it starts recuperating.
2: That's annoying indeed
3: If battery percentage is 95% or above, it doesn't recuperate. It needs to be 94% or lower..
NiU NqiX 500, 08.2026, 1000km
Vespa PX 125 E, Jg 1986, 108'000km
Lambretta 125 DL, Jg 1969
Zurück zu „NIU NQiX“
