Make Sky Blue 72V 30A Wifi MPPT Solar Charge Controller 2200W
Forumsregeln
proof
Roller: Super Soco TC Max
PLZ: 8
Tätigkeit: Fachinformatiker
Beitrag von proof »
Model No.72V 30A
Charging mode: MPPT Maximum power point tracking automatically
Charging: 3-stage:constant current(MPPT),constant voltage(Absorption Voltage),floating charge
System type: 72V battery
System voltage automatic recognition: 72V (DC60V~DC90V)
Soft Start Time: ≤1S
Dynamic Response and Recovery Time: 100us
Max Efficiency: ≥98.2% (Voc is 1.5 or 2 times than battery, then it’s the best efficiency)
PV Utilization: ≥99%
Self Consumption: ≤1.2W
Input Specification: Voc Range of PV
( Make sure the Voc of PV meets the requirement on the right.
If Voc is 1.5 or 2 times the battery voltage, it’s the best efficiency. )
DC100V~DC190V
The Maximum Nominal PV Power:(The total power rated of PV can’t be over this watt that will break the controller.)2200W
Output Specification:Selectable Battery Type, (Default is Sealed battery), Vented/ Sealed / Gel / NiCd / Lithium battery
Absorption Charging Voltage: You can set it from 72V to 102V
Floating Charging Voltage: You can set it from 72V to 102V
Overcharging Protection Voltage: 90V
Rated Output Current: 30A
Output Voltage Ripple-peak: 100mV
Output Voltage Accuracy: ≤±1%
Indicating: LCD
Refer to the manual Protection Function
Temperature Protection: 75 °C / 167℉
Fan-on Temperature: >45 °C / 113℉
Fan-off Temperature: <40 °C / 104℉
PV Reverse Polarity Protection: Yes (When Voc<100V only)
PV Over-voltage Protection: Yes (When Voc>190V, the controller will be burnt.)
Battery Overcharge Current Protection: Yes
Battery Overcharge Voltage Protection: Yes
Battery Low Voltage Protection: Yes
Enclosure: Acoustic Noise ≤40dB
Cooling Way: Forced air cooling
Components: Industrial grade
Size (cm): 21.5*11.5*5 cm/8.46*4.52*1.96 in
Net Weight(Kg): 1.3kg/2.86lb
Gross Weight(Kg): 1.4kg/3.08lb
Safety: EN 62109-1 EN 60730-1 EN IEC 61000-6-3 EN IEC 61000-6-1
Protection Category: IP21
Environmental Condition: Indoor
Operating Temperature: -20℃ ~ +55℃ / -4℉ ~ + 131℉
Storage Temperature: -40℃ ~ +75℃ / -40℉ ~ + 167℉
Funktion Einwandfrei, ideal auch zum direkten Laden von 72V Elektrofahrzeugen, ich ludt damit eine Super Soco TC Max.
Gekauft: Januar 2025.
Da von Privat ohne Rücknahme oder Garantie.
Preis: 80.- € + Porto.
Zurück zu „Ich verkaufe...“
