Exo Bikes
PLZ: 41564
Exo Bikes
Beitrag von Evolution »
http://exo-bikes.eu/
SPECIFICATIONS
PERFORMANCE
Maximum speed 45 km/h
Acceleration 0-45 km/h in ca. 6 sec
Range 40-80 km
COMPONENTS
Brakes: front hydraulic disc brake
Brakes: rear hydraulic disc brake and regenerative braking
Tires 12 inches front and rear
Front fork Adjustable hydraulic suspension
Rear suspension Adjustable hydraulic suspension
Frame Welded aluminum
BATTERY AND ELECTRONICS
Type LiFePO4, Lithium iron phosphate
Capacity 30 Ah (1,5 kWh) or 42Ah (2 kWh)
Nominal voltage 48V, Cell voltage 3.2V, 16 Cell series system
Charging time, standard charger 8-10 hours, 4A charger
Charging time, fast charger 2,5-4 hours, 10A charger
Expected life 50 000 km to 80% capacity
Built in information display Speed, battery state, odometer
Smartphone compatibility 5V USB charging, Bluetooth data transfer
Motor Brushless DC, outer rotor, neodymium magnets, 2 kg
Motor power Nominal 2.0 kW, maximum 3.8 kW
DIMENSIONS
Weight 76 kg (incl. batteries)
Wheelbase 1078 mm
Length 1520 mm
Seat height 775 mm
No. of storages 1
Carrying capacity 130 kg
https://youtu.be/ys2oXhm19x0
https://youtu.be/sGq7nwddxZk
https://youtu.be/iuilL1HnZIo (<---- Nicht nachmachen!)
https://youtu.be/cwmKAkz3_5c
