Tromox Mino
derdude
Roller: Tromox Mino
PLZ: 72070
Re: Tromox Mino
Beitrag von derdude »
Ah, okay.
Ich kenn mich da nicht aus. Dann halt 110/80/10 :D
vlad_vy
Roller: Tromox Mino
PLZ: 1
Re: Tromox Mino
Beitrag von vlad_vy »
deadropine,
Purely out of curiosity, I tried to disconnect the on-board computer (VCU). To my surprise, Tronox Mino continued to work, but the dashboard stopped displaying: speed, battery charge, battery temperature, distance, side stand condition (P), ready to move (READY), time. But otherwise everything works: if side stand is out, the throttle is blocked; if you fold a side stand, press the READY button and the throttle is activated; press the READY button again, the throttle is blocked; the turn signals work and are displayed on the dashboard; the emergency light works and is displayed on the dashboard; the speed switch works and is displayed on the dashboard; the low/high beam are switched. In short, you can drive without VCU at all, if you have a GPS speedometer/odometer and voltmeter.
So, you can test controller settings without VCU.
Zuletzt geändert von vlad_vy am Mo 3. Okt 2022, 09:49, insgesamt 2-mal geändert.
derdude
Roller: Tromox Mino
PLZ: 72070
Re: Tromox Mino
lol. Testest Du das mal?
Und wo stöpselt man die VCU denn ab?
Schönen Feiertag noch! :)
deadropine
Roller: Tromox Mino
PLZ: 8
Re: Tromox Mino
Beitrag von deadropine »
@vlad_vy
@derdude
UntiI now I have never disconnected the VCU. I think you just have to pull out the plug. The VCU is located on the right side of the bike beneath the plastic cover. It seams like there is some kind of sealant which you would have to remove. Did you do that? If you push back the small lid of the VCU there is a tiny switch which will switch of the VCU. Maybe that will also work. I have reprogrammed the LINGBO Controller and increased the maximum RPM to 3000. It was set at 2250 RPM. If you calculate the theoretical speed with 2250 RPM you get a value of 47 km/h. With 3000 RPM you get 63 km/h. Unfortunately somehow the VCU is responsible for the speed limitation, so nothing happened. I will give it a try and see what happens when the VCU is disabled.
vlad_vy
Roller: Tromox Mino
PLZ: 1
Re: Tromox Mino
To disconnect VCU I just to pulled out the plug. The latch is on the back side of the plug.
Do you try to change:
"Speed limit ratio (%)" = 100%
then
"Speed limit enable" = 0: Disable
(or "Speed Limit function switch" = 0: Disable)
Zuletzt geändert von vlad_vy am Mo 3. Okt 2022, 12:25, insgesamt 1-mal geändert.
derdude
Roller: Tromox Mino
PLZ: 72070
Re: Tromox Mino
I found the VCU and also the tiny switch. I'll try it tomorrow if it works when the switch is set to off.
deadropine
Roller: Tromox Mino
PLZ: 8
Re: Tromox Mino
@vlad_vy
I tried that but it did not work. In my opinion it only works for certain controllers. The description found very often in the web is for special controllers where a speed limit can be set independently without a switch. They are also using a different LINGBO software version.
derdude
Roller: Tromox Mino
PLZ: 72070
Re: Tromox Mino
Ich muss jetzt nochmal nachhaken...es wird vermutlich nicht reichen die VCU einfach auszuschalten, sondern es Bedarf (vermutlich) einer Umprogrammierung?!
E-zeRaider
Roller: Tromox Mino
PLZ: 70***
Re: Tromox Mino
Beitrag von E-zeRaider »
@derdude wenn Du einen Händler hast der sich da auskennt, kannst Du den mal bei Gelegenheit fragen ob man hier zu Lande auch an den großen 38ah Akku kommt…? Das wäre auch ganz interessant und dürfte nochmal ein paar Kilometer extra geben. Auch das is wieder so ne Sache die ich nicht verstehe, warum nur in China und nicht bei uns… und wenn es jetzt mit dem Speed an die VCU geht wird mir das ehrlich gesagt zu speziell :lol: bin doch nur ein armer Noob, der auf ner langen Geraden kein rollendes Hindernis sein möchte :roll:
deadropine
Roller: Tromox Mino
PLZ: 8
Re: Tromox Mino
I just unplugged the VCU and took a ride. The bike did not drive any faster (GPS) although I changed some parameters.
Like vlad_vy said, the display does not show the speed and battery status. Somehow it seems like I cannot get access to the right controller parameters with the Lingbo Software. I think only Tromox or the distributor can help.
Zurück zu „Tromox“
