Lingbo LBMC HK2A ZWK060050-B-A2 ZNEN ZHEN 12C-260-BS
Schnabelwesen
Roller: Vectrix VX-1
PLZ: 2411
Re: Lingbo LBMC HK2A ZWK060050-B-A2 ZNEN ZHEN 12C-260-BS
Beitrag von Schnabelwesen »
Sorry, bei mir war natürlich der DC DC Spannungswandler zerschossen, nicht der Controller. Danach hatte Fasemann ja auch gefragt.
szupek
Roller: vionis ksr
Land: anderes Land
Beitrag von szupek »
kamil28 hat geschrieben: Sa 24. Sep 2022, 20:39
Hi, I need TP8485E, do you still have them? Is the communication possible after soldering this chip on the board?
The same story here, I already ordered some on aliexpress. I am also wondering if after soldering this chip, communication will be available.
kamil28
Roller: NONE
PLZ: 5223
Land: anderes Land
Beitrag von kamil28 »
szupek hat geschrieben: So 25. Sep 2022, 10:41
Unfortunately, they are not available in Europe and Aliexpress is the only option :( mine were ordered yesterday, let me know if you were able to establish communication, I'm super curious.
szupek
Roller: vionis ksr
Land: anderes Land
Mine just arrived, I will be trying to solder and establish a communication.
szupek
Roller: vionis ksr
Land: anderes Land
After I soldered the chip, I could not connect like before. @ALDI_Pilot, did you solder anything else except this chip? There are some spots that connect pins 6 and 7 to tx and rx - didn't you put any resitor or shunt there? Now it looks like there is some response from the chip, Rx on my uart flashed, but it cannot be recognized and I end up with timeout or nothung from device message.
kamil28
Roller: NONE
PLZ: 5223
Land: anderes Land
szupek hat geschrieben: So 9. Okt 2022, 16:55 After I soldered the chip, I could not connect like before. @ALDI_Pilot, did you solder anything else except this chip? There are some spots that connect pins 6 and 7 to tx and rx - didn't you put any resitor or shunt there? Now it looks like there is some response from the chip, Rx on my uart flashed, but it cannot be recognized and I end up with timeout or nothung from device message.
Which USB dongle are you using for the connection? Which software?
szupek
Roller: vionis ksr
Land: anderes Land
I used CH340 chip and several pl2303 chips and result was the same.
I used "LBGUI_v120.17.0222" "LBGUI_v121.18.0329" "LBMC GUI v4.0.0" "LB GUI v121.20.2300K3AP for K3AP Controller" "LBMCGuiV3" and also no difference.
I bought logic analyzer to play around with it for a while during winter :)
kamil28
Roller: NONE
PLZ: 5223
Land: anderes Land
szupek hat geschrieben: Fr 4. Nov 2022, 21:46 I used CH340 chip and several pl2303 chips and result was the same.
In this case, you should to use RS485 serial communication USB dongle. Are you able to try with this one and let me know if it's working?
szupek
Roller: vionis ksr
Land: anderes Land
kamil28 hat geschrieben: Mi 9. Nov 2022, 19:20 RS485 serial communication USB dongle
Ho do you know of that? Is this confirmed info? BTW, I responded to your PM :)
slash_spb2
PLZ: 1
Beitrag von slash_spb2 »
Hello!
I'm interesting in this theme. Seems there is NIU proprietary protocol with cyphering on RS485 bus. I do some sniffing but data every time different.
Here xample of packets on NIU RS485 bus:
fe fe fe fe 68 20 df 68 01 01 34 05 59 ff
68 20 df 68 81 05 37 44 94 f1
Did you get any result?) I want to try connect to SWD bus of STM, but 90% it will be locked...
