Battery data analysis project
Haupt-Forum für alle NIU Elektroroller-Modelle
nuovoutente
PLZ: 0000
Beitrag von nuovoutente »
Hello everyone I needed to know the battery data, I built this object. It connects via wifi,I have all the battery information,even charging. Future implementations to be evaluated: connection to the smart home, for remote control or automation.
Falcon
Roller: Benzhou YY50QT6
PLZ: 79
Meister
First Nation Indigener
Foundation Mitarbeiter
ADR Fahrer
Pensionär
Re: Battery data analysis project
Beitrag von Falcon »
servus,
danke für die info, und wo ist die frage?
Willst du das verkaufen oder willst du uns dazu etwas zur technik erzählen? ich weiß es nicht.
gruß :)
nuovoutente
PLZ: 0000
I wanted to share my project, to understand if it was interesting and if it could be improved.
error
PLZ: #
Beitrag von error »
So you are from Italy? Would you please share some details about your project? Will it work with the BCD in my N-Pro/N-GT?
nuovoutente
PLZ: 0000
I come from Italy, I guess you understood it from the username.
this was my proof-of-concept, it is based on an ESP32 and a module rs485.
proof-of-concept
proof-of-concept
the final result, my first post, is to make it more easily transportable, robust and implement more advanced functions that ESP32 can offer, in addition to the reading of the battery data, the possibility of being controlled / connected to the network create automations, such as: during the winter, when the use of the bike is more limited, the possibility of keeping, the batteries, in storage mode.to avoid problems caused by the continuous complete charge provided by the charger, or vice versa by its complete discharge.with the possibility of reading the data, while it is charging, with the addition of the port for the charger.
in charging reading the data
I wanted to post this project of mine also to have suggestions or problems from other users, and be compatible / solvable with my project.
error hat geschrieben: Do 10. Sep 2026, 22:32 So you are from Italy? Would you please share some details about your project? Will it work with the BCD in my N-Pro/N-GT?
I don't know what the acronym BCD refers to, basically my project reads the data coming from the battery pack.
Falcon
PLZ: 79
Meister
ADR Fahrer
Pensionär
Ciao e grazie mille, quella spiegazione ci serviva proprio :)
Hai stampato tu stesso la presa e la spina? Metti a disposizione anche i file di stampa dei componenti elettronici? Su GitHub o altrove, per poterli riprodurre, oppure li vendi come kit?
Grazie mille e buona giornata
Hi, and thank you so much! We really needed that explanation :)
Did you print the socket and plug yourself? Do you also make the print files for the electronic components available? On GitHub or elsewhere, so I can reproduce them, or do you sell them as a kit?
Thank you so much and have a nice day.
Hallo und vielen Dank! Die Erklärung war wirklich hilfreich. :) Haben Sie die Buchse und den Stecker selbst gedruckt? Stellen Sie die Druckdateien für die elektronischen Bauteile auch zur Verfügung? Auf GitHub oder anderswo, damit ich sie nachbauen kann, oder verkaufen Sie sie als Bausatz?
Vielen Dank und einen schönen Tag noch!
vsm
Administrator
PLZ: 12
Beitrag von vsm »
Ich bitte um Unterhaltung in deutsch oder deutscher Übersetzung mit englischem Original.
Please post in German language or use a German translation along with the original in English.
NervaFahrer
Roller: Nerva EXE2
PLZ: 5
Beitrag von NervaFahrer »
nuovoutente hat geschrieben: Do 10. Sep 2026, 20:37 I wanted to share my project, to understand if it was interesting and if it could be improved.
Hey nuovoutente
Ja, du kannst dein Projekt verbessern.
Sendet dein ESP32 die Daten über den CAN-Bus? Läuft dein System mit 500 kbps?
Verarbeitest du die Daten live und spielst du sie von einer Datei wieder ab?
Viele Grüße, Nervafahrer
Hey nuovoutente
Yes, you can improved your project.
Your esp32 send the Data from CAN-Bus? Your System is running with 500 kbps?
You work with Data live and Replay with file?
Greetings
Nervafahrer
NervaFahrer
Roller: Nerva EXE2
PLZ: 5
Take a look here: viewtopic.php?t=48380
Schau einmal hier viewtopic.php?t=48380
nuovoutente
PLZ: 0000
Falcon hat geschrieben: Fr 11. Sep 2026, 07:54
I bought the socket, it has components that are difficult to recover. The socket and all the casing is printed in 3D.
I'm considering whether to publish everything, I would like to do something well thought out in case I want to continue to publish other projects, as I do it as a pastime, keeping everything would take me time on other projects.
Ich habe die Buchse gekauft, sie hat Komponenten, die schwer wiederherzustellen sind. Die Fassung und das gesamte Gehäuse sind in 3D gedruckt. Ich überlege, ob ich alles veröffentlichen soll; ich möchte etwas gut Durchdachtes machen, falls ich weiterhin andere Projekte veröffentlichen möchte, da ich es als Freizeitbeschäftigung mache, würde es Zeit kosten, alles bei anderen Projekten zu behalten.
NervaFahrer hat geschrieben: Fr 11. Sep 2026, 08:43
Hey nuovoutente
Hey nuovoutente
Greetings
Nervafahrer
thanks for your answer,I took a look at your link.I don't work via can-bus,what module do you use for your can-bus?
on this project I focused more on batteries. the information obtained is live.with the possibility of being able to be saved in order to do SOH (state of health) of the batteries, I can not guarantee the accuracy, compared to the use/methods of professional products, I think it can improve the accuracy with a greater amount of data collected.these are the other features that can still be implemented with the current hardware, but I cannot guarantee their current success as I have not tested them.
Danke für deine Antwort, ich habe mir deinen Link angesehen. Ich arbeite nicht über Can-Bus.Welches Modul verwendest du für deinen Can-Bus?
Bei diesem Projekt habe ich mich mehr auf Batterien konzentriert. Die erhaltenen Informationen sind aktuell. Mit der Möglichkeit, sie zu speichern, um SOH (State of Health) der Batterien durchzuführen, kann ich die Genauigkeit im Vergleich zur Nutzung und Methoden professioneller Produkte nicht garantieren, ich denke, es kann die Genauigkeit verbessern, wenn mehr Daten gesammelt werden. Das sind die anderen Funktionen, die mit der aktuellen Hardware noch implementiert werden können, aber ich kann ihren aktuellen Erfolg nicht garantieren, da ich sie nicht getestet habe.
Mitglieder in diesem Forum: marc7779 und 23 Gäste
