E-ODIN - Diskussionsthread
bob2.0
Roller: e-Odin 2.0
PLZ: 116
Land: anderes Land
Re: E-ODIN - Diskussionsthread
Beitrag von bob2.0 »
MarcS hat geschrieben: Mo 11. Mai 2026, 12:37 I want to charge 80% only most of the time, and once every two months charge up to 100% and let the balancer work.
FWIW, another reason I abandoned the 52V-88V charger was because I wanted to decide if I actually would like this spec, which is more money but allows from 10V to 90V charging, so I could use it for 12V batteries too!
https://www.aliexpress.com/item/1005008606642255.html
I also just noticed these are now 'Bluetooth', too, maybe that is a nice feature and can watch charging progress?
Description
report
Model Number: Lithium battery charger
Specification: 1850W
Voltage range: 10V-92.4V
Current range: 3A to 12A/15A/20A/25A/30A adjustable.
If you buy 3A to 25A version , 10V-74V can reach 25A; if more than 74V, current is 1850/charge voltage.
If you buy 3A to 30A version , 10V-61V can reach 30A; if more than 61V, current is 1850/charge voltage.
Weight: about 1.75KG
Input voltage: AC 185-250V, DC 310V. ( can't be used for 110V ).
Product size: 22cm*11cm*7cm
Pedator92
PLZ: 266
Beitrag von Pedator92 »
bob2.0 hat geschrieben: Mo 11. Mai 2026, 16:03
This charger have no Bluetooth, only wifi. I wrote with Google's ki an esp8266 Code that bring the data to our home wifi Network.
Lowest Current are 3A, it goes lower if the battery are almost full.
Stanford STF A4 | 5700+2700km | 75,6V 47,1AH
bob2.0
Roller: e-Odin 2.0
PLZ: 116
Land: anderes Land
Pedator92 hat geschrieben: Mo 11. Mai 2026, 17:57 This charger have no Bluetooth, only wifi. I wrote with Google's ki an esp8266 Code that bring the data to our home wifi Network.
There are buyer reviews showing a wifi connection, but there is also one that appears to be showing a blue tooth?
I don't know for sure, just repeating the advert. Whatever it is, better than having to go to the garage in the rain! :)
WhatsApp Image 2026-05-11 at 17.29.19.jpeg (63.07 KiB) 4578 mal betrachtet
baracus1983
Roller: Elektro Motorrad Roller ⚡ TS-MAX
PLZ: 24329
Beitrag von baracus1983 »
@ Bob
ok interesing ..... i made a foto of my plug i wonder is that the usual or does the 2.0 come with different ones (google says its called HG-F.B-Z850B custom made / rare ) ? since the link i posted the plug seems to be a different yet it is posted as a official part for the 2.0/3.0 so i'm a little confused ......
those chargers of yours what plug/connectors come with it ? i guess 2 ways to charge it, anderson plug is on the battery as a 2nd option
most chargers eg. on ali express don't even show the plug, so often theres no way to know ,
the easiest (to me) if there would be adapter for the various plugs, but i have not seen any so far, so how did you solve it anyhow getting the right plug ? so the easy part is to get one that supports "LI ION" + 84v , but the hard part seems to get the fitting plug (which for electronic nerds i guess is easily solvable as well)
@ predator
was genau wären denn die eckdaten von deinem gerät, hätte grundsätzlich interesse
bob2.0
Roller: e-Odin 2.0
PLZ: 116
Land: anderes Land
The plug is the part that you have to work around, if you get another charger.
But those little pins do nothing and are not special. There is no 'communication' with the bike, other than a 'safety earth' contact that stops the motor if it is connected.
I guess, you could argue it is the plug you are paying for, with a 'genuine' charger. Some do come with that connector, I forget what it is called.
But I recommend considering replacing that plug and make your life easier.
I think that plug is terrible and badly placed. Mine has a different plug/socket fitted and they are better, easier and cheaper to buy so I just replace them on my chargers.
But, yes, solving 'the plug' is part of the problem of getting another charger.
I have installed this sort on my chargers;-
viewtopic.php?p=400029&hilit=plug#p400029
The socket, which has a waterproof cap, is installed on one of the side panels and is wired to the bike at the original plug. So, that original plug remains but I wrapped it all up with self-amalgamating tape so it is sealed up. I also installed a fuse into that wiring to that socket, as I don't entirely trust cheap Chinese chargers (even the original one).
It is so easy and reliable to connect and remove. You insert and rotate it, and it locks with a click, then you just press the release lever to withdraw it. No fumbling, no pressing or pulling.
jeff-jordan
Roller: Classico LI & Z-Odin
PLZ: 6...
Beitrag von jeff-jordan »
If you want to use the genuine charging port (at the rear, underneath the seat), you can use a conversion cable or use a male 2+6 plug that fits.
But I wouldn't risk more than 15A current (20A should be the nominal limit for this kind of connector, if you trust chinese specs :roll: ).
You can find a lot of them at AliExpress, like here, here or here (just a few examples).
Classico Li 05/2020 11k+ km & Z-Odin 12/2021 43k+ km :idea:
bob2.0
Roller: e-Odin 2.0
PLZ: 116
Land: anderes Land
jeff-jordan hat geschrieben: Di 12. Mai 2026, 12:55 If you want to use the genuine charging port (at the rear, underneath the seat), you can use a conversion cable or use a male 2+6 plug that fits.
Did I misread earlier, was BMS limit 12A, we settled on?
Could it take more?
20A would be a useful increase. 12A is too little to make a difference.
jeff-jordan
PLZ: 6...
bob2.0 hat geschrieben: Di 12. Mai 2026, 19:18 ...
The BMS of the E-Odin battery doesn't limit the charging current, it's a "common port" bms. In theory you could charge and discharge our battery with the same current. Incidentally, you can even set "stopbackcurr" and "maxbackcurr" to 40 A and 60 A, respectively, allowing you to charge the battery with up to 60 A during recuperation.
In fact only the "wiring" of the charging port limits the current.
bob2.0
Roller: e-Odin 2.0
PLZ: 116
Land: anderes Land
jeff-jordan hat geschrieben: Mi 13. Mai 2026, 08:04
Oh!
I thought the BMS could shut off an over-voltage/over-charge scenario.
So, the charge port is basically just exposed battery terminals (via thin wires)?
The thing is this; I was considering installing a few extra batteries in my top box with an 'ideal' active diode from them to the battery. If I were to do that, I might as well run a new charge port to the back of the ideal diode, then it'd not only be safer but I know what's actually going on.
If there is zero extra protection using the charge port, then maybe there are better solutions. Is that right? It does nothing (for safe operation), using the charge port than the battery terminals?
jeff-jordan
PLZ: 6...
bob2.0 hat geschrieben: Sa 16. Mai 2026, 09:47 ...
Yes, why shouldn't it?
There are still some MOSFET between the cells and the negative battery terminal (C-).
So the BMS still can do it's job to protect the cells and cut off power if there is a shortcut or overload (>150A) .
Exactly. Just yesterday, I measured the cable cross-section for the charging port, it is approximately 4 mm². So the charging port ist fit for about 40A.
This aligns with the types of chargers that DAYI previously offered: the standard 10A charger (which is included with the bike), a 25A model, and even a 40A model.
However, as far as I recall, the 40A model was subsequently discontinued.
The "battery connections" on the large, heavy-duty Anderson connector consist of the positive terminal of the cell packs (the thick red 6 AWG cable) and the C-terminal (the black 6 AWG battery cable) of the BMS.
So there is still protection.
Regarding your intention to stow additional batteries in your top case: I am not sure if that is really a good idea. Such batteries are very heavy, and you would need a permanent connection to the vehicle's battery (otherwise, differing states of charge or voltages could occur).
Furthermore, in the event of an accident, this significantly increases the risk of a short circuit.
Zurück zu „Dayi Motors“
